DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Bosch 20/25 boiler lock out
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
snafu
from United Kingdom
PostPosted: Sat Sep 17, 2005 9:48 pm Reply with quote
Hi, our 20/25 combi boiler has run dry of oil & keeps locking out... presumably theres a bleed screw on the oil pump which needs opening?
I have marked the only thing I can see which is like a bleed valve... is this it or is it round the back of the boiler somewhere?
Back to top
 Alert Moderators
jiminblack
from United Kingdom
Thanked: 178 times
PostPosted: Sun Sep 18, 2005 9:12 am Reply with quote
On the Oil pump (below control box) open the allen screw marked with the arrow out or P until oil dribbles out with no air bubbles.
Back to top
 Alert Moderators
snafu
from United Kingdom
PostPosted: Sun Sep 18, 2005 8:03 pm Reply with quote
Thanks for the info, tried to bleed it out but no joy... left the bleed valve out for 10 mins but virtually nothing coming through. I think there is a feed problem, I tried to replace a blocked inline filter which caused the lock out in the first place. Call out to the engineer I think
Cheers again
Back to top
 Alert Moderators
jiminblack
from United Kingdom
Thanked: 178 times
PostPosted: Sun Sep 18, 2005 8:50 pm Reply with quote
Have you a Teddington oil fire safety valve fitted?
http://www.tedcon.com/index.php?cursite=TedCon&curpg=Fire-Valves
If so check it hasn't tripped. They have a little plunger on the base, make sure it's pushed in.
Back to top
 Alert Moderators
COG
from United Kingdom
Thanked: 1 time
PostPosted: Sun Sep 18, 2005 8:56 pm Reply with quote
I your oil tank above the oil pump to start with if not your in for a bit of bother, the test poin you indicated is to atach the pressure gauge to set oil pressure but can be used to vent if you have ran out of oill, hold the brass section solid with say an adjustable spanner then open the nut (dont remove ) with an 11mm spanner then place an old rag around said nut,siwtch on the burner and as soon as you feel the oil spraying into the rag shut down close the test point and fire back up.
Back to top
 Alert Moderators
snafu
from United Kingdom
PostPosted: Sun Sep 18, 2005 10:24 pm Reply with quote
Yes something like it, I cracked the down stream joint & plenty of oil there
The boiler was serviced by a WB engineer 2 weeks ago, he couldn't get it to fire after the service with the inline filter in place - it did look pretty clogged up.
So he left the filter out & the problems only started when I put a new element in place. Boiler couldn't draw through the new filter & even with the filter removed again it's not happy. The new flexi hose he put in looks a bit twisted/flattened, I'm wondering if its restricting flow
In any case I think I need to get the engineer out to take a look, I'm chickening out of undoing things I don't understand & having oil spraying about!!
Cheers for your help guys
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester Danesmoor 20/25 Intermittent lock out 9 200 Thu Nov 06, 2014 10:16 pm
Worcester Greenstar Heatslave 12/18 lock out still on 13 6700 Wed Jan 27, 2010 11:28 am
oil tech guys. burner lock out on worcester heatslave 20/25 9 80 Tue Jan 03, 2012 10:30 pm
Worcester 240 RSF Air Lock? 3 380 Wed Oct 01, 2008 11:20 pm
Worcester Heatslave Combi 20/25 lock out 2 2620 Mon Oct 17, 2005 9:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
