DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Boiler pressure dropping
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Katade
from United Kingdom
PostPosted: Fri Aug 22, 2003 4:31 pm Reply with quote
The boiler in my house (Valliant) was inherited from the previous owner, hence no instructions. I have to keep on opening a valve to underneath the boiler to increase the pressure as it keeps dropping below the red line (just below 1 bar). The other day I forgot the switch the valve off and the pressure went above 3bar and the overflow was dripping (which was good), but within 3 days the pressure was below the marker. Surley this can't be right. I should not need to keep on topping up the system every week or so, should I? What could be wrong?
PS - I can't see any leaks in the house and all the rads are okay.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Fri Aug 22, 2003 6:50 pm Reply with quote
sorry to state the obvious but you do have a leak somewhere. If its of any use I had the exact same problem, turned out that the drain valve (under the ground floor) was not tight, we are talking 1 drip /10 minutes but over time it was enough to cause the pressure to drop
Back to top
 Alert Moderators
Tin Gill
from United Kingdom
Thanked: 1 time
PostPosted: Fri Aug 22, 2003 8:42 pm Reply with quote
I had a similar problem with my Vaillant combi and it turned out to be the pressure valve for the overflow that had begun to stick and so never shut properly. You mentioned that when the pressure went above 3 bar the overflow was dripping - you might want to check it's not dripping all the time.
Back to top
 Alert Moderators
Gees
from United Kingdom
Thanked: 11 times
PostPosted: Fri Aug 22, 2003 9:25 pm Reply with quote
I still have a leak somewhere.. It takes about 3 weeks to drop by abt. 1/10 of a bar. can I find it? Can I H**L.
Back to top
 Alert Moderators
COG
from United Kingdom
Thanked: 1 time
PostPosted: Sat Aug 23, 2003 9:26 pm Reply with quote
Anything much more than 1/2 a bar over three months is too much, every time you top it up your adding fresh water which means more oxygen which means more corrosion. Dont expect to see a puddle of water from it is more likly a trickle from a rad valve or the PRV passing
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1097 times
PostPosted: Mon Aug 25, 2003 10:17 am Reply with quote
You won't find a leak that small probably, they tend to evaporate straight away. I'd add Leak Sealer - get it in a plumbers merchant and ask them how to get it in the system .
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Mon Aug 25, 2003 11:05 am Reply with quote
my opinion is that when the system over pressurised the Pressure relief valve opened, quite correctly, but has not closed off properly. In my experiance this is due to a bit of muck in the seating and the sealing washer has corroded and needs replacing
If the pressure drop never happened before then a system leak is unlikely but it won't hurt to put some leak sealer in as ChrisR suggests
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Mon Aug 25, 2003 11:08 am Reply with quote
I think the problem is that when the system over presuurised the Pressure Relief Valve opened, quite rightly, but has failed to close off correctly due to a bit of muck or the sealing washer being corroded.
if the drop never happened before then a system leak is very unlikely but it won't hurt to inject some leak sealer in as ChrisR suggests
Back to top
 Alert Moderators
pb
from United Kingdom
PostPosted: Mon Dec 08, 2003 12:17 pm Reply with quote
I have a similar problem but cannot find any visible leak site. Does anyone have any views on one possible explantion:-
There is at least one location where a leak would not be visible/obvious. If general hot water tank (HWT) is also heated by the boiler CH circuit then there could be a leak in the loop passing through the HWT. The direction of leak would of course be from hi to lo pressure. Thus, if the CH circuit is at higher pressure than HWT then water will leak (unseen) into the hot water tank until p difference is zero.
A clue as to whether this explanation is valid would be to check the pressure to which the boiler CH circuit levels out to following topping-up from main. If that roughly equates to the pressure head in the HWT circuit then maybe the leak is within the CH circuit where it passes through the HWT. One bar of pressure is approx equivalent to 30 foot head of water.
Incidentally, does any one know why the Vaillant Instruction Manual warns that " No inhibitors must be added to the C.H. system"? Surely that would only be tenable for the ideal situation of a system that is perfectly sealed and thus the supply of oxygen limited?
Back to top
 Alert Moderators
jcb
from United Kingdom
PostPosted: Wed Mar 10, 2004 8:19 am Reply with quote
I am also having a problem with a pressure drop about .2bar per day, it is coming from the pressure release valve. Is it just a matter of replacing the valve or could there be another cause???
Back to top
 Alert Moderators
Galileo2004
from United Kingdom
PostPosted: Fri Mar 12, 2004 12:40 pm Reply with quote
Same problems here with my Worcester Heat Systems Combi. I have now turned off all the radiators (valves off at both ends), put more water in so that the pressure returns to 1bar and will wait to see if the pressure drops back to zero again (which normally takes 2-3 days).
The pressure release valve may be dripping, but its hard to determine when its raining outside.
Does anyone have any other suggestions on where to find the leak?
Back to top
 Alert Moderators
murphytanya
from United States of America
PostPosted: Tue Sep 29, 2009 5:02 pm Reply with quote
The pressure at my boiler drops below 1 bar (it takes about 2 weeks to drop to 1/2 bar). I do see a visible leak at the top of the expansion tank that is hooked up to the boiler. Would a leak in this location be causing the pressure drop? I was told by a plumber that it would not, since the flow of water from the boiler to the radiant heat system doesn't pass by the expansion tank. Any thoughts?
Back to top
 Alert Moderators
buck51
from United Kingdom
Thanked: 100 times
PostPosted: Tue Sep 29, 2009 5:14 pm Reply with quote
Why do you think, pb, jcb, & Galileo2004, did not get a response???
Start your own post this one died twice 2003 & 2004 then you may get a beter response than they did.
Back to top
 Alert Moderators
findaleak
from United Kingdom
PostPosted: Fri Mar 05, 2010 4:40 pm Reply with quote
Hi Everyone
If you have leaks you cannot locate, check out findaleak.co.uk they are the central heating leak gurus !!
Cheers
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Wed Jun 02, 2010 8:07 pm Reply with quote
spam spam spam
wonderful spam
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Combi Boiler Pressure dropping - no visible leaks 38 33300 Mon Oct 26, 2009 12:00 pm
Brand new bosch boiler pressure kept dropping... 7 560 Sun Jan 24, 2010 5:52 pm
Boiler pressure dropping 7 60 Sat Nov 30, 2013 10:49 am
Boiler Pressure keeps dropping 2 520 Sun Dec 28, 2008 8:47 am
Boiler Pressure Dropping 3 60 Sun Dec 08, 2013 2:55 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
