DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ideal W2000 combi boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Maddogsk
from United Kingdom
PostPosted: Sat Oct 01, 2005 6:42 pm Reply with quote
The pilot light on this boiler will light but once I let go off the gas supply button (having held it in for a minimum of 15 seconds) it just goes out.
I have cut the power to the boiler and turned the gas thermostat dial to zero as per the instructions.
Does my boiler need a service or am I doing something wrong.
Please help as we've no hot water or heating at the mo.
Cheers
Back to top
 Alert Moderators
dfg
from United Kingdom
PostPosted: Sat Oct 01, 2005 7:15 pm Reply with quote
it needs a new thermocoulpe
Back to top
 Alert Moderators
Maddogsk
from United Kingdom
PostPosted: Sat Oct 01, 2005 7:21 pm Reply with quote
Sorry to sound ignorant but what doe sthis part do and how does it rectify my problem?
Thanks for reply.
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 853 times
PostPosted: Sat Oct 01, 2005 7:49 pm Reply with quote
It';s a thermo electric device which sits in the pilot flame, heat causes an electric current to flow across two dissimilar metals, the current flow travels thgrough an overheat thermostat which if the boiler overheated would cut the flow of current, the current terminates at a solenoid known as a power unit, inside the ,multifunction control valve (gas valve). Inside the power unit the current from the thermoelectric device applied to a coil causes a magnetic field which holds a valve open against a spring. The spring ensures that the valve shuts the moment the current fails to arrive. The valve allows gas to the main burner, when you hold the button in you artificially hold this valve open but the moment you let go the power unit has to take over or no gas and flame goes out.
Now normally the faulty part is the thermocouple, occasionally it is the over heat thermostat, seldom but also occasionally the power unit. Incorporated in oh stat problems are the possibilities of the leeds to it shorting the current to ground.
In any case it is a job for a member of a class of presons deemed competent.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Sun Oct 02, 2005 6:32 pm Reply with quote
ideal w2000 is not a combi so if you can`t get that simple bit right call someone in.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
ideal W2000 combi boiler is it poorly? 16 1280 Tue Mar 13, 2007 10:34 pm
Ideal W2000 Boiler Not Igniting 3 3020 Sun Jun 05, 2005 10:07 am
Problem with Ideal W2000 RS40 Boiler 9 1060 Tue Mar 11, 2008 7:51 pm
Ideal W2000 boiler can't get pilot light going! 6 3100 Mon Nov 27, 2006 12:04 pm
Ideal W2000 boiler fault 11 360 Sun Oct 03, 2010 10:06 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
