DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Building Garden Walls
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
stevenrafferty
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 06, 2005 7:18 am    Post Subject:
Reply with quote Thanks
Planning to build a couple of garden walls which will be retaining.
Was planning to build them out ot dense concrete blocks but is this overkill, would I get away with a lighter (and cheaper) block?
Was planning to build only a single skin of blocks, but laid on the large face, so that there is still enough strength and I get the required thickness
thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
TexMex
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 06, 2005 7:44 am    Post Subject:
Re: Building Garden Walls
Lightweight are just not suitable. They absorb moisture, then disintegrate.
You can do but there are other methods. What height are you planning to build?
Back to top
 Alert Moderators
stevenrafferty
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 06, 2005 9:23 am    Post Subject:
both walls are only 2 1/2 to 3 feet high
Back to top
 Alert Moderators
TexMex
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 06, 2005 6:17 pm    Post Subject:
Like I say, you can lay them blocks the way you describe, but it wouldn't be my prefered method.
The number of blocks used would be identical to a cavity wall of the same surface area. The cavity wall would be thicker than the solid wall you propose. (although the cavity should be filled) You could then elect to use bricks on the outer skin. Although somewhat more expensive than the blocks, they give an acceptable finish without any further work. If you were going to render your wall, the savings here would offset some of the extra cost.
If you want to stick with solid blockwork, you also have the option of the 9" hollow ones. These are a bit trickier to lay, but go up quicker than the method that you propose. Once you have the wall to height, you can then fill with concrete to bond them all together.
You may also find these posts of interest as they concern a similar project.
http://www.diynot.com/forums/viewtopic.php?t=31163
http://www.diynot.com/forums/viewtopic.php?t=31272
http://www.diynot.com/forums/viewtopic.php?t=32003
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Retaining Garden Walls 3 480 Tue Apr 27, 2004 2:34 pm
Damp proofing for garden walls? 5 660 Tue Feb 06, 2007 3:27 pm
Building and rendering a garden wall 9 2560 Mon Apr 04, 2005 12:32 pm
Garden wall foundations - Building Help 3 400 Tue Jul 22, 2008 12:46 pm
Building Garden Shed - How many blocks required? 4 780 Fri Jun 23, 2006 6:35 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
