Colour Coding of Meter to Consumer Unit Tails
6 Oct 2005
Wiltshire
A 3 phase supply comes into our community hall - previously used for storage heaters. Electricity board supply head is colour-coded R, Y, B. The red and yellow phases are no longer connected to anything. The blue phase has a service fuse from which a blue tail goes to the meter and thence the consumer unit, all tails in blue for live and black for neutral.
Consumer unit has blue incoming live but all outgoing live is red.
Periodic Inspection Report says the "identification" is incorrect.
Any suggestions as to what is the technically correct remedy would be gratefully received. Can I get away with a warning notice only?
Mr Fixit
Mr Fixit
i think it should be a red meter tail, since its only operating on single phase.
why couldnt they just use the red phase when they converted it? Been much better and clearer . . . :rolleyes:
because they need to balance the phases. cant just shove everything on L1
theres only one phase being used . . . does it matter which one? if all the supplies were picked at random, they would be balanced, surely? Or do they actually work it out, how many are on each phase from each transformer? :confused: thought the random selected was more likely . . . ;) ;)
probably random
but you said why couldnt they use the red phase
Thanks for the advice. With blue being the new neutral colour I can see the need to stop using it for live. Glad that you are not saying it has to be brown tails. Yet !
You seems to be saying that it will be OK to connect red tails onto the service head fuse (which has a blue spot on it). Seems common sense as the electricity board will realise it's single phase. I just hope common sense in this situation.
I read that black is one of the new colours for live in 3 phase (brown, grey and black). Is that common sense or is it Crazy !! :eek:
Mr Fixit
If you can still get red tails, yes. Are you qualified to do this work?
It is crazy, but as long as warning notices are sited, any accidents can be put down to the next spark's lack of attention to this notice. ;)
I think this could quite easily be DNO territory, please contact them before you do anything.
