Indesit Evolution1600 WE16
8 Oct 2005
Berkshire
The machine doesn't click over to spin cycles, just keeps washing until reset and manually clicked over.
sounds like a partial blockage in your pump housing.
the machine needs to get rid of water before spinning. if it's partially blocked it will be draining some but not enough in the time allowed. when you set it to spin only you are starting it off from a partially drained position and it therefore is able to complete the drain out and perform the spin.
in short - check your filter on the right side behind the kick-plate.if there is nothing in it try taking the hoses off to look for a sock or coin etc.
Thanks very much for your advice. I'll give it a go and let you know the outcome.
