DIYnot
Local | Network
   DIYnot > Forums
Local | Network
knocking noise from boiler
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
jarvo
from United Kingdom
PostPosted: Sun Oct 09, 2005 9:46 am Reply with quote
hi,
i have a potterton prima 30 b that has recently started making a banging/knocking noise when it comes on.
This happens for both central heating and heating the water.
I have read a few things and i know it could be a few different causes, not enough water in the system, bubbles etc.
Is there anything i can do to narrow down the cause before i call out a plumber.
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 15 times
PostPosted: Sun Oct 09, 2005 9:52 am Reply with quote
The first thing to check is that there is sufficient water in system. If it's a sealed system with a pressure gauge on the boiler, the pressure should be 1 bar or so. If an open system fed by a tank, is the tank water level above the outlet pipe?
Back to top
 Alert Moderators
jarvo
from United Kingdom
PostPosted: Wed Oct 12, 2005 8:37 am Reply with quote
Thanks for the replly,
i will take a look later roday.
Back to top
 Alert Moderators
jarvo
from United Kingdom
PostPosted: Sun Oct 23, 2005 4:36 pm Reply with quote
finally got around to looking at the system.
(been away on business for most of the week)
The system is an open one, the water level is above the outlet valve and about 3cm below the overflow valve.
However the water is brown and full of sludge.
the noise has developed and there is a continous knocking noise from the boiler whilst it is on.
is it possible that the water needs flusing out??
Back to top
 Alert Moderators
jarvo
from United Kingdom
PostPosted: Mon Oct 24, 2005 9:38 am Reply with quote
heres 2 images of the dirty water, ignore the fish net i was using it to scope out the dead spiders floating on the surface.
Took a bit of water out to show the father in law as he used to be a plumber/fitter at a power station.
The tank had about a 4 inch gap where dust/dirt/spiders etc could get in.
Think im going to get the system flushed on wednesday, its a 8 radiator system.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Knocking noise whenturning on hot water - BG C1 combi boiler 9 1780 Fri Dec 07, 2007 5:37 pm
Constant knocking noise in pipework, NOT BOILER! 15 2920 Sat Dec 31, 2005 12:34 pm
Knocking noise from pipes/boiler even tho' boiler is off 2 1180 Mon Mar 13, 2006 12:13 am
Pipes making a creaking/knocking noise 6 1740 Mon Jan 22, 2007 10:27 am
Knocking noise coming from upstairs radiators 3 1040 Sun Oct 23, 2005 5:35 pm
DIYnot
