A periodic inspection report (PIR) is when an electrician comes around and does an inspection and test of the installation. The report should highlight to you any problems with the installation.
few hundred, depending on where you live etc. if your wiring is old then i would recommend you get 1 so you know just how bad or good the wiring is. the report will also detail things that are wrong so you can make changes
