DIYnot
Local | Network
   DIYnot > Forums
Local | Network
combi boiler keeps losing pressure
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
fitzy
from United Kingdom
PostPosted: Mon Oct 10, 2005 9:54 pm Reply with quote
my combi boiler (worcester 9.24 electronic) keeps losing pressure i have checked all related pipework and radiators for leaks but found none.
while the system is running the outside overflow pipe has a steady drip/flow coming throught it.
when the the system is started say for hot water it makes a hell of a racket and i have to repressurize it and push the reset button before it will run can any one help thanks. icon_sad.gif
Back to top
 Alert Moderators
DarkInferno
from United Kingdom
PostPosted: Mon Oct 10, 2005 10:32 pm Reply with quote
fitzy wrote:
... for leaks but found none.
Found it!
fitzy wrote:
... while the system is running the outside overflow pipe has a steady drip/flow coming throught it.
Probable case is faulty/depressurised expansion vessel, which sounds like it has gunked up the PRV seal too.
Back to top
 Alert Moderators
meldrew's_mate
from British Virgin Islands
PostPosted: Tue Oct 11, 2005 8:24 am Reply with quote
Fitzy, take the white front cover off and find the red expansion vessel, about 12" x 6". Locate the inflation point and stick a matchstick in it like you were letting down a neighbour's tyres (if you're stuck ask a teenage hoody for help). If water comes out you need a new vessel. If nothing, or just air comes out it may be salvageable.....
....Take a bike tyre pump and put about 20 good strokes into it, watching the pressure gauge. If it goes up put another 30 in, or stop when the pressure gets to 2 bar. Bleed the upstairs rads and recheck the pressure, pump more air in to bring pressure back to 1 bar.....
....Check the PRV outlet, if it still drips you need a new PRV. If not turn the heating on and watch the gauge as it warms up. If it goes over 2.5 bar wait for it to cool, then put 20 more strokes of air in, re-bleed to get pressure down to 1 bar, and re-try.
If some is good, more is not necessarily better, so don't overdo this.
Put the cover back on.
Back to top
 Alert Moderators
fitzy
from United Kingdom
PostPosted: Wed Oct 12, 2005 9:34 am Reply with quote
i have tried the expansion vessel and water is spraying out as you suggest i may need to replace it is this expensive and is it possible i can purchase one and do the job myself or do i call in an expert icon_question.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3486 times
PostPosted: Wed Oct 12, 2005 5:13 pm Reply with quote
Its a very old boilerand you should be planning to replace it!
A cheaper solution is to fit a stand alone ex vessel on the heating circuit.
Or as a temporary solution ( 12 months ? ) isolate a rad and take 8 litres of water then put it back WITHOUT bleeding, the air at the top will then act as the ex vessel.
Tony
Back to top
 Alert Moderators
thumper1
from United Kingdom
PostPosted: Wed Feb 11, 2009 10:00 am Reply with quote
I have the same peoblem. May seem like a silly question, can I replace the valve assuming its the the same/similar to bike tyre valve<a silly question
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
losing pressure on combi boiler 10 2820 Mon Jan 05, 2004 11:35 pm
Combi boiler leaking but not losing pressure 12 280 Mon Aug 08, 2011 9:32 pm
gas boiler/combi losing pressure 5 80 Tue Oct 25, 2011 8:27 pm
Combi boiler losing pressure 2 480 Tue Mar 31, 2009 7:41 am
New Alpha combi boiler losing pressure 2 100 Thu Aug 07, 2014 8:06 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
