top rads cold bottom rads hot
21 Oct 2005
Essex
have read the comments on this however have beeen bleeding rads many times to get rid of air, water comes out of bleed on rad ok.water is cool rads valves r new 2 all rads (tops)gravity system running on baxi boiler. have bled rads with pump off however when system fires up rads r cool or luke warm...checked 4 water in expansion tank and is full.taken rads off and flushed through and re placed still no good. have no zone valves on system only a pump...could this b a problem..!! may b weak, or impeller dropped off.. but is working i can hear it running...OK ANY IDEARS PLS.. should i replace pump. this is driving me mad...!!!!!!!
Bahco said:
Try bleeding the pump by unscrewing the nut in the middle. :D
THKs 4 ur advise but there no nut on the middle of pump only a black screw knob which i undone but this just turns the pump impeller..!! :D
