MANDATE said:As I recall, the distance of electrodes to burner was not ajustable, there being a dowel pin and hole.
Potterton do however have a test procedure and fault finding chart
PM said:The PCB on my boiler, and 3 neighbours, had faulty components that had burnt out. This seems a common fault. It took about 30 min to replace and cost approx £150 for a new PCB. You can DIY if you follow rules e.g. switch off electric before opening panel. I did mine and my neighbours with no drama's.
