Bosch WFD2060 washer doesn't like move!! UPDATE
25 Oct 2005
Leeds
Can anyone help? We've just installed our washing machine in our new house and, since the move, it doesn't want to work.
Its a Bosch WFD2060. There are three vertical lights on the panel (from the top: \\\'spin\\\', \\\'rinse\\\', \\\'wash\\\'). The machine starts up and takes in water, but then stops with the \\\'spin\\\' and \\\'wash\\\' lights flashing. The machine restarts when you press the start button, but then stops again throughout the cycle with the same lights flashing. When this happened during the rinse cycle, i pressed start and the machine seemed to start the programme from the beginning again, as the \\\'wash\\\' light went on. There doesn't seem to be any problems with draining and spinning.
We've made sure that the transit bolts are removed, the machine is level on the floor and the pump propellor at the front is free from obstruction.
Update: After reading other posts on this forum (thanks everyone!), we checked to make sure that both water feeds were working properly. The washer filled up with water much quicker than before and the warning lights didn't come on. We thought we'd cracked it.
However, the washer didn't seem to take in very much water at all during the rinses and the warning lights came on again.
any more ideas??
thanks very much in advance.
Welcome
Is it still under warranty?
What make of machine?
You can try the manufactures web site for helps also
Diyisfun said:
Welcome
Its a Bosch WFD2060 and about 4 years old. there's no warranty on it anymore. Unfortunately, neither the user's guide or the website can help...
