Cold Rads Downstairs
26 Oct 2005
Central heating system worked with no problems, untill I replaced a leaking valve on one of the upstairs radiators. I drained the system and replaced the valve and refilled the system, all the rads are full of water and the pipes going in and out of the pump are hot. Help the other half is going mad! :confused: :confused:
Try bleeding rads and pump. Also make sure your 3 way valve is switching over to mid position to allow heat to rads side. :D
