Hotpoint Aquerius wash/dry
18 Oct 2008
Devon
My daughters machine has stopped drying, can anyone give me the resistance of the dryer element.
thanks alan
The actual resistance is not important, it will either read a few ohms (good) or infinity ohms (bad).
Thanks Fidom, my reading was 1 ohm, I did'nt think that was enough.
Alan
Ah, that sounds like a short circuit if your meter is on the correct range. Remove both wires from the heater and check the resistance between a terminal and the metal bracket where the heater is screwed to the machine. If that also reads one ohm you need a new heater.
