Stone resin vs stonecast shower tray?
5 Mar 2004
Hi all
Need to make an urgent decision about shower tray which is due to be fitted into downstairs shower room this week :eek: . Originally requested that builder quote for installing stonecast/cast stone shower tray, as I read that this would be more suitable for any 'heavyweights' wanting a shower (even tho it costs £ :eek: :eek: :eek: to install). When I mentioned this to the plumber, however, he raised his eyebrows and said I wanted a stone resin (acrylic?) shower tray. :confused:
Which would you suggest, please? I've read through previous posts, and know I need to take into account access in case of blockages, etc. Which type of tray would be more suitable for access?
Also, re shower doors - what is the minimum thickness of glass you'd recommend, please? 6mm?
Many thanks
Only ever noticed 2 types- the cast resin ones which often have "stone" in there somewhere, and the acrylic ones. They both used to break if not supported well, but seem to have improved. Most popular are the stone resin cast ones which go from around £35 , rising exponentially with size.
My personal preference for practicality are the ones which come with legs and side panels. About £120 for an 800 square. Easy to level them and they don't need a reinforced floor.
Hi Chris - thanks for your reply. Are the stone resin trays the ones that need to be bedded onto sand and cement, or don't they need anything as they have legs? (It will be going on top of floorboards). Also are there any makes you'd recommend?
TIA
