DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Odours from toilet pan
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
bobapcoed
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 02, 2005 4:18 pm    Post Subject:
Reply with quote Thanks
This will take some explaining. I'v got an en-suite bathroom and a main bathroom. The main bathroom has just been re-furbished. There is no external vent to either, formally a drago valve in the en-suite, now a drago in both. On occassion (regular but not every time) when the en-suite is used (be it basin/shower/toilet) we get smells in the other bathroom. We've got anti-vac on everything, the drago valves are working fine, and there is no pull on the new pan when the other one is flushed. The stack is fine (checked with smoke bombs even), barriered off physically in case, and the waste has not been altered at all except for the extra drago valve, which was fitted to try and remedy the problem. Now many will find this hard to believe but with water in the base of the pan, and no pull, smells are eminating from the pan about 3 minutes after usage in the other bathroom. Plumbers look at me sceptically. I've got a feeeling this pan is not British but it must have been licensed and it was bought here. It's not the pan connector as the bloke I got in to do the drago re-did it.When we use the re furbished bathroom there is never a problem. The smell is not constant, just when the other bathroom is used.
Should the pan be changed, although the plumber thinks it's ok. Ultimately I plan to vent outside, will this do it. Any advice would be greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
TexMex
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 02, 2005 8:33 pm    Post Subject:
I take it the draco valves you refer to are Air admittance valves. These allow air in (to prevent a partial vacuum forming behind the flushings, but do not allow positive pressure out.
Your problem could be caused by a partial blockage further down the system. Rather than try to describe it, I thought I'd take this opportunity to play around with Paintbrush and Gif animator to demonstrate.
Although this assumes the partial blockage to be in the nearest inspection chamber, it could be anywhere really.
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 57 times
PostPosted: Wed Nov 02, 2005 9:15 pm    Post Subject:
Tex. I just love those animations. What are you using?
joe
Back to top
 Alert Moderators
TexMex
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 02, 2005 9:54 pm    Post Subject:
I use Paintbrush to draw the pictures then Microsoft GifAnimator to pull them together. It's totally free, you only need the executable which you can download from here
First you create every frame that you want (save them in .gif format).
Make a backup copy of the last frame.
Open Gif Animator.
Open file (choose gif that is to be your last frame.)
Then use the Insert button to add the gif for the frame before.
repeat for all the other frames (working backwards until you reach the first)
Then for each image you setup how long you want it to appear.
Save the file and job's done.
Back to top
 Alert Moderators
bobapcoed
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 03, 2005 3:52 pm    Post Subject:
odours from pan
Texmex, thanks for your answer, a strong possibility and very entertaining too. Cheers
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Loud piping and horn noise when we flush toilet 6 260 Thu Apr 17, 2008 8:08 am
Toilet waste for sink waste 4 160 Mon Apr 14, 2008 4:24 pm
installing a new toilet 13 560 Tue Apr 22, 2008 1:01 am
toilet leaking 7 220 Sun Apr 20, 2008 12:36 pm
ok my toilet 6 200 Sun Apr 20, 2008 7:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
