Joined: 03 Nov 2005 Posts: 5 Location: London, United Kingdom Thanked: 0 times
Posted: Thu Nov 03, 2005 3:14 pm Post Subject:
CU features
Gents
In tandem with revising most of my lighting circuits I plan to have the existing consumer units replaced. There are currently 2 boxes with cartridge-type carriers (second one originally had 6 fuses for storage heaters).
Given the expense of all the other work I do not intend to skimp on the CU, but what features/specification (mandatory or nice-to-have) should I be looking for (board split, RCD protection, case type, recommended manufacturers, etc.) ?
In addition to the existing assignments on the main board I plan to add the storage heater circuits (already converted to regular power sockets) in 2 groups, bring in the new power and lighting circuits, plus add dedicated breakers for computer and alarm feeds.
This will provide a lot of flexibility but if all are kept separate this will be 12 or 13 assignments – is that excessive in a 3-bed property ?
Most of the walls and floors/ceilings are concrete so I want to make this project a one-off, to be good for 30 years.
My role is limited to the new wiring and CU supply. The live stuff is for a.n.other.
Your advice, please.
Joined: 15 Apr 2005 Posts: 12856 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Fri Nov 04, 2005 9:48 pm Post Subject:
how many do you have? You lighting a football stadium?
Nowadays it is normal for houses to have split load consumer units with one side protected by a 30mA RCD unit, usually downstairs sockets, shower, any outdoor electrickery, high-risk circuits. (regs state sockets likely to feed power tools and outdoor electrics need RCD protection)
as single radial feeds? If this is the case, buy a cheap second consumer unit and fill it with 16 or 20A MCBs, run off a 40 or 45A MCB in the RCD side of the main CU. Neater and saves space in the main CU.
normal in a house that size is probably 6-8 circuits, getting those seperate radial socket circuits into a seperate box (as they were with the old storage heaters) will achieve this.
computer and alarm feeds should go on non-RCD side afaik
Posted: Sat Nov 05, 2005 7:13 pm Post Subject:
Thanks for the comments.
As you note the storage heater sockets are on separate radials – of the 6 originals, 2 have been/will be deleted by building works and 1 is now dedicated to IT kit. I had planned for the other 3 to be pulled together into a single RCD, cable length permitting. Can you see any problem with this ? (I too appreciate neat work).
A bit more scene setting: the property was originally 2 maisonettes. All power cables (ring & radial) are buried somewhere in the floor. Original lighting circuit is MICC are buried in the walls and ceiling. Most of the structure is reinforced concrete and I’ve never had much luck using cable finders, even when I know where the cable must run. The MICC circuits emerge out of the concrete behind the CU.
I’ve no idea why the place was built so, I’m just trying to deal with the consequences and am now no fan of domestic MICC.
I am fixing up false ceilings to enable recessed LV lighting fittings to be installed and am taking the opportunity to run new cables from each area (L & R, up & down) back to the CU – hence 4 separate runs.
The outside (roof terrace) electrics are fed from a ring main spur (with fused RCD unit).
As it stands, assuming I amalgamate the radials, I will end up with 10 assignments, with those marked * on the RCD side.
*Cooker
*Ring Main (org.)
*Radials
*IT
*Ring Main (short new)
Lights (4)
Alarm
Joined: 30 Sep 2005 Posts: 139 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Sun Nov 06, 2005 11:17 am Post Subject:
That sounds a good idea. Hmmm PCs and alarms from this thread, fridge/freezers from another. I'm beginning to get the impression that every room on the house needs to be on 2 separate rings, RCD and non-RCD !
__________________ I may take 10 times as long, but all the decent professionals are too busy to look and estimate.
Posted: Sun Nov 06, 2005 12:12 pm Post Subject:
no but seperate radials for things like fridges and freezers - and other things for which RCD tripping would be a problem - are a good idea.
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
Posted: Sun Nov 06, 2005 12:47 pm Post Subject:
The items on the list below may not all apply to you, but they are worth looking at to get you thinking:
Upstairs sockets
Downstairs sockets
Kitchen sockets
Circuit for appliances
Cooker circuit
Non-RCD circuit for F/F
Non-RCD circuit for CH boiler
Dedicated circuit for hifi
Dedicated circuit for IT equipment
Upstairs lights
Downstairs lights
Immersion heater
Shower
Alarm
Supply for outside lights
Supply for garden electrics
Supply for shed/garage
Plus any peculiarities brought about by your house layout & construction - e.g. in mine because of solid floors and where the rest of the sockets are, I have a radial just for one socket in the hall, the doorbell and the porch lights.
Plus a few spares on RCD & non-RCD sides for expansion beyond that for future unforeseen needs.
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
