could someone help please? i've had a 9.5kw triton shower for about 6 years now, worked great. when i fitted it i checked the wiring was suitable and i think it is. i'm sure it comes straight from the fuse box, which has a 30a fuse, and it's roughly about 10 metres of 10mm cable. i also changed the pull cord switch to 1 that is recommended for a 9.5kw shower. the only problem i've had is that i've had to change the pull cord switch about 3 times because the switch gets harder and harder to pull on and off and eventually snaps the cord, so i just leave them turned on. the last time i changed it i noticed the wires had been overheating and had to cut them back. could this be because the power is constantly on? the switch came from homebase. the other thing is could i install a 10.5kw shower with this wiring and the correct pull cord fitted?
