Hi all.
I have a central heating / hot water problem funnily enough ! Here's the cast of characters : Honeywell 3 point power head. Grundfos pump (UPS 15-50x18 Model C)... new last christmas. Potterton EP2002 Controller and a Potterton Netaheat Electronic wall hanging boiler. Problem. I'm no tech head so here is my view of things. Room stat is always on max as we have thermostatic rad valves and cylinder stat is on 140f and system has run fine all summer. Obviously we just simply hav'nt run the CH system. Well, we fired up the CH about 2 days ago and all we heard was a horrible mechanical clicking (Not boiler as this was/is on for HW). Traced the sound to the power head. When being turned on the switch (?) inside was rotating being driven by a tiny gear, but seems to be slipping/resetting back to original position repeatedly. In my infinte wisdom I jammed the switch lightly in the open postion and everything worked fine ... until today. (PWNED ! guilty!!) Today we swtitched the HW on and heard a horrible screaming/gurgling sound. Fiddled with switch and sound has dissapeared but now the pump does'nt vibrate (as though it is'nt working) and just gets hot. we also can't hear any water moving. So is the powerhead dead ? If so do I just replace the motor part or the whole thing ? Btw, we did a test thing which is described on the net where we turned room stat to min and cylinder stat to max, put switch in auto and urned in the CH. The boiler fired up but no obvious working pump.
Help.
Help.
