Servis Washer/Dryer - not spinning
16 Nov 2005
Berkshire
Servis Model : M911B (circa 1992 made by whirlpool I think)
Everything works fine except the final spin just tumbles at low speed. (I'm not sure about intermediate spin during rinse).
Whilst testing and fiddling, it has worked twice.
In its early life it blew three motor control modules but has been fine for about ten years.
Having read through many posts, motor brushes sound like a possibility - but this makes no sense to me since the motor still operates at low speed. Since it has worked a couple of times, I'm thinking it's something mechanical like the timer, but the motor control module still seems likely.
Slow spin also fails on another part of the dial.
I've waggled and generally checked for loose connections.
Any thoughts would be much appreciated.
Try it with the machine empty or with dry washing in, if it still won't spin it is probably a timer fault and perhaps time for a new machine. Another possibility is a blocked pressure vessel but this would give other symptoms like overfilling or not filling at all.
