Have a Thorn Apollo 30/50 conventional boiler piped in a Y plan configuration controlled by a Honeywell ST6400C programmer with a Honeywell V4073A mid position valve. Firstly my high temp stat is dead, i know this because if i let it run on central heating only it will continue to heat till the safety cuts in and extinguihes the pilot. Therefore for the meantime i'm having to use the "low" stat. I have two probelms with the boiler though and was wondering if anyone can help:
1. Boiler noise when running on central heating only - Have bled,bled and better bled it but boiler makes a bubbling hollow sound as if there\\\'s not enough water in it. Btw the pump is relativly new, makes no difference at different pump speeds. I have opened up the bypass fully but it does not quieten down?, when running "hot water" or both it's fine????
2. Pump overrun feature - Does anyone know how to make this feature work with a 6400C programmer?????
Please help me, i really have had enough of this wretched system!!!!
Cheers
Stu
Cheers
Stu
