Heating Only On When Hot Water On
roz
25 Nov 2005
Yorkshire
What are the likely causes. The heating works fine when the hot water is on but goes off when the water reaches correct temp. Thermostat clicks when room set temperature is reached but nothing happens. Is it the thermostat or something just like a switch down in the boiler? Novice needing answers!
You haven't provided much information there! Could you read and follow the guidance here?
