No water in the central heating system.
I was bleeding a radiator last night and it suddenly went dry.
There is water in the header tank and if I turn the bleed on at that pipe (just before the pump) I get water. However there is no water after the pump even before the 3 way valve. Is it a problem with Sludge in the pump? If I turn the pump on water seems to flow but not very well.
Thanks Chaps
Thanks Chaps
