suprima 50 water pressure
7 Oct 2003
I have a 2 year old Suprima 50 and the water pressure is at almost zero. How do I get this back up? what do I put it up to and any ideas why it would be at almost zero in the first place? .... arrrggghhh! :mad:
its zero cos its got a leak somewhere
filling it up is done via a filling loop (does no one read the other posts in here must have done this a thousand times now :rolleyes: :rolleyes: ) which will be located near ythe boiler, in your case near a big red vessel, it is normally a silver hose between two taps. turn them on fill up to 1br turn them off
Hi john,
I'm confused!.I didn't think the 'suprima 50' was a combi boiler.
I assume we are talking Potterton. Can you confirm?
:rolleyes: :rolleyes: :rolleyes:
Read the other posts,
use search to find "filling loop", "expansion vessel",
pay for help if you can't do it,
remove the filling loop when you've finished,
find out why it leaded.
Corgiman, I think I'll store this in a text file and just paste it several times a day, Yawn, yawn.... you can copy it if you like ;)
before you do that you check the spelling find out why it leaded. leaded? :LOL: you seem to have the same problem i do. (you type the right letters but not necessairly in the right order)
MANDATE said:
Hi john,
its not mandate but its one ofthose pesky small cast iron heat exchanger boilers that can be converted into a sealed system,..
