DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
new shower
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
howthickami
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 02, 2005 5:48 pm    Post Subject:
new shower
Reply with quote Thanks
Had a 7kw shower for years which has given up the ghost. Been told I can go up to a 7.5kw without having to change wiring. Also have a combi-boiler now, does that make any difference regarding the electric shower. Sorry, only a lowly woman and changing a plug is the as far as my knowledge on anything electrical goes.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Fri Dec 02, 2005 6:41 pm    Post Subject:
You may be able to go higher still (even 10.5 kW is possible) on your existing wiring, depending size and on length of run, etc. Best to get professional advice on this, since it gets quite technical.
The combi won't effect the electric shower, but you might want to consider a thermostatic mixer shower (£60?) running off the combi as an alternative. This will give a much better flow (double?) than even a 10.5 kW electric one, but will require the hot supply pipe being brought up to shower point.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
slippyr4
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 02, 2005 6:46 pm    Post Subject:
Which probably won't be as costly as you might think: the hot supply is probably already available at the bath tap.
Thermostatic mixer showers generally look better than the electric blobs anyway.
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Fri Dec 02, 2005 6:53 pm    Post Subject:
...and much cheaper to run!
__________________
Let's face FAQs.
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 3 times
PostPosted: Fri Dec 02, 2005 8:23 pm    Post Subject:
My advice is to stick with the electric shower as when your combi breaks down then at least you will be able to get some hot water.
__________________
Eagles may soar high but Slugs" don't get sucked into jet engines
Back to top
 Alert Moderators
plumberman_uk
from United Kingdom
Thanked: 0 times
PostPosted: Wed Dec 21, 2005 12:04 am    Post Subject:
i take your shower is above the bathtub? get a bathmixer with shower attachment and rail(between £40 and £80) the combi will give you better flowrate on the hotwater than any electric shower... icon_idea.gif
__________________
.... and if that don't work, we call in the proffessionals!
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Wed Dec 21, 2005 7:03 am    Post Subject:
Not suitable for use with a combi! Only bath/shower mixer to use is one with built in thermostatic control - £250ish.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
New Shower Required 2 120 Tue May 06, 2008 7:52 pm
low pressure vs high pressure shower controls 3 200 Wed May 07, 2008 2:03 pm
new mixer shower, plus pump=weak/no cold water! Help please! 26 720 Sun May 11, 2008 8:21 pm
Power Shower pump not starting - Showermate 1.4b Twin 7 1460 Tue May 13, 2008 7:37 am
Grohe Wirless Shower 12 520 Tue May 06, 2008 12:39 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
