washing machine leaking
5 Dec 2005
Nottinghamshire
There is a small but significant leak coming out the bottom of my washing machine. Checked the door seal and its fine. It is dripping out of the bottom.
Is it seal on the drum? Is it fixable? How much do you reckon it will cost?
The machine itself looks like it’s got a few years left in it but its not a very expensive one.
Thanks in advance.
Lawrence
I had a similar issue with my LG. Turn the washer upside down and look where the outlet pipe is at the front of the machine.Check around that area for cracks etc.I found a crack there and sealed it with steel putty, end of problem.It took me about two days to figure that one out!
Impossible to say where it's leaking, you can only find that out by investigation.
Unplug your appliance before working on it
