Catherine
Joined: 16 Oct 2003 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Oct 16, 2003 10:57 am Post Subject: Door Sill treatment |
I have a victorian door frame and sill and the sill has gaps where the plaster is worn and chipped away, can anyone recommend the best way to replace it? Also if I fix the sill, should I buy one of those metal guard things and if so what are they called and where would I get one?
thanks in advance |
masona
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Fri Oct 17, 2003 7:40 am Post Subject: |
See this from previous post to help you.The metal door sill cover are specially made up as there're all difference type of sill.Usually a good brass hardware shop can make one for you,but you must give them the template shape fo your sill etc. |
