my system is only 5 years old and I have a Glowworm 40 e and a megaflow,
The boiler when starts up ticks four times and then sounds if its going to blow up, after about 5 minutes it has turned itself off again,
Today i noticed the water pressure was quite low so i set it to its orginal pressure setting water has started to come out of boiler,
any suggestions on the correct setting for this,
also should i have instant hot water with this system
thanks
thanks
