DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cant sweat a joint
This topic originated from the How to page called Repairing a burst pipe
Click here to return to the page called Repairing a burst pipe.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
ES
from United States of America
Thanked: 0 times
PostPosted: Mon Oct 20, 2003 11:12 pm    Post Subject:
cant sweat a joint
Reply with quote Thanks
I have tried several times to solder a soft copper pipe coming from my well to a copper fitting where it was leaking.Each time the connection leaks. I replaced all the fittings and have soldered pipes before. Does anyone know what I can do other than a compression fitting to fix this problem.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
joseph
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 21, 2003 7:38 am    Post Subject:
Is the joint you are trying to solder totally dry, any moisture will ruin the joint. i know this from personal experience. The heat will also draw moisture / water along the pipe making it difficult even if it looks dry to start with. if not stick with compression fittings.
Joseph
Back to top
 Alert Moderators
evdama
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 21, 2003 10:21 pm    Post Subject:
As said, the pipes should be dry-any water will stop the process.
Also all the joint surfaces sould be cleaned (wire wool) until shiny bare metal shows all over and should not touched again with bare fingers execpt to apply a uniform smear of flux.
You will know when you're successful as the solder will melt the instant it touches the joint and disappears up around the gaps.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Wed Oct 22, 2003 5:43 am    Post Subject:
if you still can not do it after all the above advice go to your local hardware store and ask for
its a copper push fit joint
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
where to buy toilet anti sweat valve 2 200 Mon Dec 22, 2008 3:54 pm
Lead Joint 89 1620 Mon Jun 23, 2008 7:51 am
Leaking solder joint 12 700 Tue Feb 26, 2008 8:03 pm
Is there a joint compound for Central heating???? 8 420 Sat Jan 19, 2008 9:12 am
Testing a solder joint for leaks .... 3 260 Fri Aug 08, 2008 9:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
