Underfloor heating cable...query
16 May 2005
Sussex
laid 46meters of heating cable,(not a mat)the type where you do not need to return to stat(ie twin cable)
The resistance states that it should read 117.6
but on testing i get a reading of 113.0,
not over tiled yet,should i be concerned at the discrepancy,or is that with in allowed tolerance.
Merry xmas to all and a big thanks to all who contribute.
Do you have a known resistance (odd resistor) laying around that you could check the calibration of your meter with?
Personally I wouldnt have thought your reading was anyhting to worry about.
yes multi meter is all ok.
just trying to seek reassurance that i can go ahead and tile..does the reading mean that the cable is sound and all ok,or is there another test i can carry out before tiling
that rating sounds close enough to me though if in doubt check with the manufacturer.
'tis 4% out - less than the amount by which the supply voltage can vary, so it's hard to see why it should be an issue.
Also, I wonder what ambient temperature the manufacturer is expecting you to measure at?
Have to get my oar in here!!
Yes, too true, with resistance wire it has to be the ambient temperature- My guess is- you won't have to warm it up much in order to read correctly!
