DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cooker cable
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
  View previous topic :: View next topic
Author Message
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 02, 2006 3:21 pm    Post Subject:
cooker cable
Reply with quote Thanks
Just wired a 4.25kw double oven to a spare 30amp fuse on CU.I`ve used 2.5T&E from CU to terminal box near oven.From here used 2.5mm heat resistant flex to oven, as reccomended by oven instruction booklet.The T&E used from CU totals approx 3.5m in length.Would this be considered as safe? According to \\\"home\\\" section of site 2.5mm is fine up to 4800W &20A!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
pdcelec
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 02, 2006 3:25 pm    Post Subject:
Re: cooker cable
note the highlighted bits and then comment on what you see
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
You'll want to be swapping that fuse for a 20A one...
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 02, 2006 3:31 pm    Post Subject:
Couple of points..2.5T&E can certainly handle the loading as it is around 18A at 230V or 17.5A at 240V.
However, the cable is not rated at 30A and so it should not be on a 30A breaker so you should change this to 20A.
Further, what is the distance from the consumer unit to the cooker outlet plate? So long as the cable run is shorter than about 27 meters total length you will be OK for volt drop..and being domestic I would presume that this is not an issue..
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 02, 2006 3:42 pm    Post Subject:
Re: cooker cable
[quote="pdcelec"]
gedantic wrote:
Just wired a 4.25kw double oven to a spare 30amp fuse on CU.I`ve used 2.5T&E from CU to terminal box near oven.From here used 2.5mm heat resistant flex to oven, as reccomended by oven instruction booklet.The T&E used from CU totals approx 3.5m in length.Would this be considered as safe? According to \\\"home\\\" section of site 2.5mm is fine up to 480ote the highlighted bits aYnd then comment on what you see
Yes, it is rather blindingly obvious!!!!! Thanks!
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 02, 2006 3:47 pm    Post Subject:
Further, what is the distance from the consumer unit to the cooker outlet plate? So long as the cable run is shorter than about 27 meters total length you will be OK for volt drop..and being domestic I would presume t hat this is not an issue..
Affirmative! So all I need do is change the fuse wire from 30 to 20?
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Mon Jan 02, 2006 3:52 pm    Post Subject:
No, you need to change the whole fuse (and the base), what happens if the 20A blows for whatever reason and the person fixing it sees a 30A carrier, doesn't realise what has been done and fits 30A fuse wire?
Might be easier to purchase a 20A plug in MCB for it though, than a 20A BS3036
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 02, 2006 4:12 pm    Post Subject:
Your knowledge is very much appreciated.Thanks again!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
cooker rating and cable 11 240 Wed Mar 11, 2009 8:04 pm
Cable for cooker hood 3 460 Sun Sep 09, 2007 10:02 pm
moving cooker switch cable...please help! 11 1520 Sat Sep 08, 2007 11:46 am
New cooker cable question 3 1320 Mon Dec 06, 2004 1:52 pm
Cooker Cable Size 15 660 Sun Apr 05, 2009 4:49 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
