DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Potterton Profile boiler Starts then stops
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
lucas
from United Kingdom
PostPosted: Fri Oct 24, 2003 4:06 pm Reply with quote
I think the heat exchanger is not filling, the boiler starts runs for a minute then switches off, this leads me to suspoect it heats the water present (which is probably not a lot) this reaches temp and the thermostat switches the boiler off.
Does any one know how to prime a Potterton Profile Boiler?.
Back to top
 Alert Moderators
Tuan
from United Kingdom
PostPosted: Sun Oct 26, 2003 10:51 pm Reply with quote
I'm afraid you're pump has gone which stops the heat from dissipating (no circulation). 35 at you local plumbers merchant.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sun Oct 26, 2003 10:57 pm Reply with quote
or 34.99 at screwfix but regretfully its also + 5.99 packaging, but if you buy a "spare" as well (or some other stuff you don't really want icon_wink.gif ) packing is free
Back to top
 Alert Moderators
lucas
from United Kingdom
PostPosted: Mon Oct 27, 2003 8:50 am Reply with quote
I don't think so pump is working away, if i take the nut from the middle of the pump i can hear it moving and if i just rouch the pump 'wheel' with the tip of a screw driver i here the whirring sound you would expect and the pump doesn't stop?.
I have adjusted the pump speed through all 3 setting nothing seems to work, also the top tank over flowed last time i tried, which suggests water is being pumped up into the tank but not into the boiler.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton HE starts then stops 4 380 Tue Dec 15, 2009 11:19 am
prima 40 f boiler main burner repeatedly starts ans stops 5 640 Thu Feb 07, 2008 7:53 pm
Boiler stops and starts before getting up to temp 11 140 Sat Feb 23, 2013 10:02 am
Boiler starts and stops all the time. 4 100 Thu Dec 12, 2013 11:08 pm
Glowworm boiler starts and stops 6 3300 Fri Oct 28, 2005 9:48 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
