DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bath mixer tap - poor hot flow
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
wouldbplummer
from United Kingdom
PostPosted: Tue Jan 03, 2006 11:07 pm Reply with quote
I've just replaced my two single bath taps with a new shower mixer tap (1/4 turn with ceramic disc, suitable for low and high pressure systems). The problem is that this new mixer tap has very poor hot water flow (takes ages to fill the bath even a small way). I have excellent hot water pressure on all other hot water taps and this was also true with the former single bath taps. Also cold water pressure seems to dominate and push back the hot water when both the hot and cold are being mixed together on the new tap. Would appreciate some advice please! Would a return valve help on the hot side or is there anything I can do to the tap valve? Or have I just got to expect this with a mixer tap? Thanks!
Back to top
 Alert Moderators
bab
from United Kingdom
Thanked: 7 times
PostPosted: Tue Jan 03, 2006 11:20 pm Reply with quote
r u sure its suitable 4 low pressure. what make is it . dit u use flexi pipes under bath. is there a filter on the spout outlet. u'll never mix mains cold with low pressure hot on a cheap bath mixer. it should hav low pressue cold to it to match the hot pressure. Then u could turn on taps go to pub 5 beers then back for a bath half full a water,
Back to top
 Alert Moderators
wouldbplummer
from United Kingdom
PostPosted: Wed Jan 04, 2006 12:11 am Reply with quote
thanks for quick reply, didnt have to change any pipes my old tap conectors
fitted strait on, there is a filter on end but sure thats not prob,didnt know u needed gravity presure hot and cold who thinks of that when thay fit? so thers no easy way out of this mess then just a s design falt on the tap i think, i could go down pub all week before i had water deep enough to float my veg!.
Here's a link to the exact tap I bought (paste into address bar)http://www.taps.co.uk/applogic/productinline/579/alpha_basin_taps_&_bath_shower_mixer.html
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 873 times
PostPosted: Wed Jan 04, 2006 3:39 pm Reply with quote
Non return valve on hot would make it worse icon_eek.gif Who told you it was for low pressure icon_question.gif They should be wearing it icon_evil.gif
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1111 times
PostPosted: Wed Jan 04, 2006 3:47 pm Reply with quote
PLUMBERS do.
The mixer may have check/one-way valves built in. If not you need to add them both sides. If it does, take the HOT one out and put a 22mm one in the pipe instead. The integral ones have tiny bores.
Back to top
 Alert Moderators
wouldbplummer
from United Kingdom
PostPosted: Wed Jan 04, 2006 4:44 pm Reply with quote
can i just remove the integral check valve on the hot side and try, is it easy to remove? if the tap has not got any where can i get and how much. do i need in both hot and cold or just 22mm hot side?
Back to top
 Alert Moderators
tomii
from United Kingdom
PostPosted: Fri May 25, 2007 3:24 pm Reply with quote
Hi, did you manage to resolve this problem? I'm also having the same problem with my new mixer tap which replaces the two single old tap. The hot water on the mixer is very weak but the cold is very strong, how can this be corrected? any suggestion would be most appreciated.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Sat May 26, 2007 7:09 am Reply with quote
Looking at the info posted by the OP, his tap was not suitable for a gravity system - the link he gave quoted a pressure range of 0.5 - 5 Bar. A typical first floor bathroom with gravity fed hot system from water storage tank in the loft above will have a water pressure of about 0.2 Bar , less than half the minimum design pressure.
For a 'back of a fag packet' calculation, the water pressure in Bar is 1/10th the vertical distance from the base of the cold water storage cistern to the tap outlet.
Sorry, but Nige F is right.... If a salesman sold you the mixer as suitable for use with a gravity system, then he needs to have some basic laws of physics explained to him with the help of something large and heavy, with some particularly nasty sharp corners to use as a teaching aid.
Back to top
 Alert Moderators
marcopolo
from United Kingdom
PostPosted: Sun May 27, 2007 7:37 am Reply with quote
Any ideas for names of mixer taps for this set up then?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun May 27, 2007 8:50 am Reply with quote
TicklyT wrote:
For a 'back of a fag packet' calculation, the water pressure in Bar is 1/10th the vertical distance [in metres] from the base of the cold water storage cistern to the tap outlet.
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 158 times
PostPosted: Sun May 27, 2007 9:51 am Reply with quote
That'll be 10m to a bar then.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun May 27, 2007 10:05 am Reply with quote
That's a good enough approximation.
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 158 times
PostPosted: Sun May 27, 2007 10:11 am Reply with quote
Some things never change.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun May 27, 2007 10:30 am Reply with quote
Gravity-induced pressure does though, according to where you are on the planet.
For example, on the equator the head of water needed to generate 1 bar (not Bar) can be as much as 10.24 metres.
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 158 times
PostPosted: Sun May 27, 2007 11:39 am Reply with quote
Feeling a bit pedantic today Softus?
I'm off to watch Lewis Hamilton. C'mon the Brits.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Very poor cold water flow in kitchen mixer tap 7 1180 Mon Mar 10, 2008 3:09 pm
Changed To Low Pressure Mixer, But Hot Flow Still Poor- SOS! 4 400 Sat Apr 17, 2010 1:53 pm
Poor flow through mixer shower 3 40 Wed Oct 19, 2011 8:40 pm
poor hot water flow at the kitchen mixer. 2 880 Wed Jan 02, 2008 5:30 pm
Will Changing The Kitchen Mixer Improve The Poor Hot Flow? 3 440 Thu Oct 29, 2009 11:42 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
