cq6
Joined: 09 Jan 2006 Posts: 2 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Mon Jan 09, 2006 10:30 am Post Subject: Faulty Socket ? |
Hi There
I have a socket that has almost \\\"welded\\\" the neutral pin of the plug into it..Charred the neutral wire in the appliance plug and left burn marks on socket itself.Any ideas why this has happened ? |
kendor
Joined: 16 Mar 2004 Posts: 5066 Location: United Kingdom Thanked: 0 times
cq6
kendor
Posted: Mon Jan 09, 2006 11:34 am Post Subject: |
just another thought, plug could also have been slightly pulled out causing arcing, is the cord in a position that it can get tugged? |
plugwash
Joined: 28 Mar 2004 Posts: 6931 Location: United Kingdom Thanked: 16 times
Posted: Tue Jan 10, 2006 1:51 am Post Subject: |
whats the state of the fixed wiring cores?
if they are damaged you'll have to do something about them too. if possible cut back before the damage and reterminate. if there is not enough slack to do that then i'd cover the damaged insulation with sleeving and use emery paper to clean any black carbonisation off the ends. |
