Joined: 12 Jan 2006 Posts: 2 Location: Aberdeen, United Kingdom Thanked: 0 times
Posted: Thu Jan 12, 2006 6:18 pm Post Subject:
Dimmer selection and Wiring
My Situation:
The existing wires I have to connect a new 1 gang 2 way dimmer switch (I only need 1 way wiring) are 3 sets of cables each with red, black and earth. On the back of the old switch I am replacing, 2 of the red wires were twisted together and wired into the "top" terminal on the switch and the other red wire was connected to the other terminal on the switch. The 3 neutral (black) wires are connected together and junctioned off separately onto a plastic junction block. The earths are attached to the earthing point inside the back casing.
The terminals on the new dimmer are L1 L2 and C.
What I did:
I connected the Dimmer switch up with the single red wire in the L1 terminal and the 2 red wires that are twisted together, in the C terminal. I earthed the switch plate with a new piece of earth wire connected to the earth terminal on the back casing.
What happened:
The light turned on, dimmed up and down successfully, then shorted out over the L2 terminal (which had nothing connected to it), tripping the main lighting fuse, when I turned it off.
Question 1:
Have I selected the correctly rated dimmer switch? The dimmer I used was rated for 250W. The light is a mains ceiling mounted GU10 halogen with 4x50W bulbs.
Question 2:
Does my wiring on the dimmer seem correct? Should I use a live test tool to establish which red wire is the live and which is the switched live, or can anyone tell me given the way 2 of the red wires are twisted together and 1 is a single wire.
Posted: Thu Jan 12, 2006 6:53 pm Post Subject:
Well the back of the L2 terminal was charred and a little melted. I guess if you think the wiring was correct then its the rating of the dimmer. I need to get a 400W dimmer rather than the 250W I melted earlier today?
Joined: 31 Mar 2004 Posts: 143 Location: United Kingdom Thanked: 0 times
Posted: Thu Jan 12, 2006 7:03 pm Post Subject:
Breezer,
I wasn't being sarcastic, i was not aware of that. I just assumed you could take the maximum load e.g.200W and use the next up rated dimmer in this case 250W.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
