fan & low voltage light
17 Jan 2006
London
I have installed a fan with timer. Used ring main to supply Live & Neutral via Fan isolator switch installed outside bathroom, LS feed I have taken from the bathroom light switch. Light circuit seems normal arrangement except for the lights being low voltage i.e light switch feeds the transformer.
My problem is the fan doesnt start consistently, could it be that the inductive load of the transformer is effecting the operation of the LS switching in the fan?
My backup plan is to feed the LS in the fan from the live fan feed and use a double pole single throw switch as the light switch That would mean ring main through the light switch (Not sure that is legal)
If i understnad that right your saying you have supplied the Fan from two different sources.. permenant supply from the ring main and the switched supply from the bathroom light lighting.
If this is the case i suggest you take it back out and do it properly. You cant supply the fan from two different sources.
Also, adding to the above post. You didn't mention that you had gone via FCU when taking power from the ring to the fan isolator. Is the the case?
