MISTYJESS
Joined: 30 Oct 2003 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Oct 30, 2003 8:05 pm Post Subject: solderring |
could someone please tell me the correct way to solder joint properly from start to finish.I usually tin both pipe and joint slide them together time consuming and slow
thanks |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Thu Oct 30, 2003 8:31 pm Post Subject: |
clean both pipes with wire wool, add helping of flux inset pipe into joint heat with "blowtorch" when flux boils add more solder.(assuming its yorkshire fitting)
This assumes both pipes are dry, and also that you clean the inside of joint, and solder has dollop of flux on it __________________ Do you like music Mr Finch?
Forum = Opinions |
masona
Joined: 05 Jan 2003 Posts: 10857 Location: Essex, United Kingdom Thanked: 7 times
Posted: Fri Oct 31, 2003 10:28 am Post Subject: |
When using blowlamp point it away slightly so it draw the solder to the end joint. |
