DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how to change a junior hacksaw blade
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials
Author Message
jimbox
from United Kingdom
PostPosted: Sun Jan 22, 2006 2:38 pm Reply with quote
Kinda a stupid question I know but I have a really cheap junior hacksaw, the kind that is just a metal frame, like this: http://www.foxdiy.co.uk/view_product.php?product=TL326 but can't for the life of me get the new blade to go in. I have tried squeezing the handle together with a pair of pliers but that still didn't bring the two ends close enough together to be able to fit the blade. Any help appreciated!
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Sun Jan 22, 2006 2:43 pm Reply with quote
handle has nothing to do with it.
you push the opposite end in from the handle.
holing the handle push against something solid (wall?)
BUT, be carful as it may slip
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 660 times
PostPosted: Sun Jan 22, 2006 3:44 pm Reply with quote
just to add to breezers comments
you want to position the frame opposite the handle with the blade in against somthing solid with the frame supported just below the blade grab the handle and lean on it as said abouve carefully cos it will slip easily
Back to top
 Alert Moderators
jimbox
from United Kingdom
PostPosted: Mon Jan 23, 2006 9:13 am Reply with quote
Thanks guys. Was a struggle but I got there in the end! Think I'll buy an easy-blade-change model next time the blade needs changing!
Back to top
 Alert Moderators
keyplayer
from United Kingdom
Thanked: 18 times
PostPosted: Wed Jan 25, 2006 1:54 am Reply with quote
You already have one.
Back to top
 Alert Moderators
Gary_M
from United Kingdom
PostPosted: Fri Feb 03, 2006 9:59 pm Reply with quote
Thought I would just add - remember that a hacksaw blade should have the teeth facing forwards icon_smile.gif
Back to top
 Alert Moderators
wilhelm
from United Kingdom
PostPosted: Sat Feb 04, 2006 12:50 pm Reply with quote
at risk of starting a a massive debate on this. err i put senior blades firing forward. and junior firing backwards.
Back to top
 Alert Moderators
salem2000
from United Kingdom
Thanked: 4 times
PostPosted: Sat Feb 04, 2006 2:12 pm Reply with quote
Salem
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 660 times
PostPosted: Sat Feb 04, 2006 2:51 pm Reply with quote
part off the problem with junior hacksaws is the lack off strength off the frame so if you have the teeth forward pointing it pulls against front off the frame and can case the frame to close up and loosen on the blade which can take the tension off the the blade and cause it to cut off line kink the blade or even make it fall out
Back to top
 Alert Moderators
swelec
from United Kingdom
Thanked: 1 time
PostPosted: Sat Feb 04, 2006 2:58 pm Reply with quote
allways put my blades in with teeth pointing forward
now I know why all my blades go kinky
thanks for that tip
Back to top
 Alert Moderators
wilhelm
from United Kingdom
PostPosted: Sat Feb 04, 2006 6:17 pm Reply with quote
Back to top
 Alert Moderators
Gary_M
from United Kingdom
PostPosted: Sat Feb 04, 2006 10:33 pm Reply with quote
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 43 times
PostPosted: Sun Feb 05, 2006 2:52 pm Reply with quote
Gary_M wrote:
LOL
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials All times are GMT
Page 1 of 1
Jump to:
The best hacksaw blades 5 220 Thu Feb 09, 2012 9:13 pm
How to change a blade on a Performance Pro Mitre Sire 5 900 Wed Oct 01, 2008 3:26 pm
Blade change on Performance Power CLM250LSM Slide Mitre Saw 5 1120 Mon Sep 03, 2007 9:02 pm
looking to change my cordless drill 19 2140 Tue Mar 07, 2006 8:57 pm
quick change drill bits? 4 220 Tue Feb 26, 2013 10:45 pm
DIYnot
