during the wash cycle the tubs starts spinning as the agitator moves.it slowly gains speed until it spins very fast.what is the problem?four year old gibson toploader.the belt is not broken......help!
Based on my limited knowledge of american laundry items it would appear that the mechanism that brakes the tub during a wash cycle may be worn out or otherwise inoperative. On the ones we have here in the UK ( whirlpool ) there is a set of what can only be described as brake shoes inside a brake drum that are operatede by a solenoid coil. Have a look under your machine to see if anything has "dropped off "
