DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
removing metal posts
This topic originated from the How to page called Types of fence posts
Click here to return to the page called Types of fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
mlb3c
from United States of America
Thanked: 2 times
PostPosted: Sun Jan 29, 2006 10:34 pm    Post Subject:
Reply with quote Thanks
the posts are v shape metal posts that are speared near the bottom and approximately 5 feet long-any ideas on how to remove them? There are 15 of them.
Wow! what a great idea! I wonder why I didn't think of that. NOT. I failed to mention that it is believed (judging by one that was not installed) that is is "sunk" in the ground (very hard red clay ground) approximately 2 ft. Some very determined person who apparently found a great deal on the "posts" or whatever you call them and put cheap fencing with them--that was the easy part to take down. icon_rolleyes.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Jan 29, 2006 10:41 pm    Post Subject:
pull very hard or dig them out
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Mon Jan 30, 2006 4:28 am    Post Subject:
Here's what I did to remove some 4X4 wooden fence posts that were stuck in the ground from an old old fence along the perimeter of my parking lot:
1. I coiled a chain around the fence post (about 5 or 6 turns) and connected both ends of the chain together so that when I pulled upward on the slack where the ends were connected, the chain tightened up around the post.
2. I hooked the slack onto the top of a 2X4 and leaned that 2X4 against the post I was wanting to pull out.
3. Then I lifted the bottom of that 2X4 with a scizzor type car jack.
This would work better if you could get one of those old jacks that was meant to lift a car by it's bumper and hook the chain on that.
Alternatively, could you grab tightly onto the V shaped steel posts with a pair of Vice Grip pliers and use a piece of 2X4 as a fulcrum to pry the posts out by using a long pry bar to pry upward on the jaws of the Vice Grips?
Back to top
 Alert Moderators
Hitachimad
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 30, 2006 10:08 pm    Post Subject:
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Fri Feb 03, 2006 6:19 pm    Post Subject:
Back to top
 Alert Moderators
mlb3c
Thanked: 2 times
PostPosted: Fri Feb 03, 2006 11:31 pm    Post Subject:
I think I'll put up birdhouses instead....the posts are never coming out.
Back to top
 Alert Moderators
Goomer
Thanked: 0 times
PostPosted: Sat Mar 25, 2006 2:30 am    Post Subject:
Harbor Freight makes a puller for the metal posts. It is an incredible back saver. Lists for $35 US, I think I got it for about half on sale. I wish I had bought mine a lot of years earlier, these things can be terrible to get out after the grass and roots grow up around them. The owners manual has enough info you could cobble one up possibly. that can be found at:
http://www.harborfreight.com/manuals/38000-38999/38444.PDF
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38444
Back to top
 Alert Moderators
Drakkhen
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 25, 2006 10:07 am    Post Subject:
this seems like the typical post that can be found in France
Don't complain, in France they put cement around the post...
In France they simply cut them because to remove them is very very tough.
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Sat Mar 25, 2006 10:48 am    Post Subject:
two options, dig down to expose the top of the concrete and cut them off there and then back fill, or dig around the concrete and use a sledge hammer to loosen them then use the posts own leverage to get them out. Thats all i do when removing fence posts
__________________
have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Back to top
 Alert Moderators
chamac
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 27, 2006 9:38 pm    Post Subject:
drill a hole into the concrete and then hammer a chisel into the drilled hole
this should split the concrete
Back to top
 Alert Moderators
chamac
from United Kingdom
Thanked: 0 times
Back to top
 Alert Moderators
fiveminutejob
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 05, 2007 2:06 am    Post Subject:
Removing Metal spikes
Having struggled for ages trying to lever out the first of eight old wooden post & spikes firmly set in earth, not concreted, I simply poured some WATER down the sides of each spike (I'd already wiggled them around to create a bit of room). This provided sufficient lubrication to help each one slide out fairly easily with sufficient leverage. Saved a lot of back pain!
Hope this helps. Worked for me.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Removing Fence posts that are in concrete 3 1120 Mon Aug 18, 2003 4:59 pm
Disappearing posts, whats happening? 4 520 Fri Nov 28, 2003 7:54 pm
fixing fencing to old concrete posts 5 520 Wed Feb 19, 2003 4:23 pm
Newel Posts 2 6320 Thu Mar 28, 2002 1:07 pm
Fence posts - help 13 2920 Mon Jan 19, 2004 5:40 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
