cooker wiring
1 Feb 2006
Essex
Have just bought new gas cooker to replace old crap dual fuel.The old cooker was wired directly to its own switch,the new one came with plug attached. Can i use the the old wiring to wire up the new cooker or is it safer to use the plug.Many thanks in advance. :?:
If it's a gas cooker, the current required to run the igniter, timer and lights are very small - an ordinary socket will be plenty. Leave the old cooker outlet in case some day an electric cooker is fittted.
It is possible to turn a cooker circuit into a radial socket circuit, and plug the gas cooker into it, don't know if that's worth the trouble. You need a suitable fuse for the gas cooker as the cooker circuit is probably 30 or 40 amps. You need to be able to get at a switch to turn the cooker off safely and easily in case of trouble or maintenance.
Slight hijack but might be a relevant answer to the original question. Would fitting a switched FCU in place of an existing cooker switch or connection unit (asuming a single sized 45A plate in an appropriate position) and leaving the cooker cct MCB at 32A or higher be considered acceptable ? I would imagine on a 32A supply this should be OK but maybe not if it's greater than 32A ?? Fitting a socket is not good (IMHO) in respect of having no RCD protection to cover for the potential use of portable equipment, particularly if it could be used outdoors.
