Quick question, should the pressure on a combi system vary slightly with ambient temperature?
I had a leak on my heating system fixed by a plumber, to enable this to be done, I had to remove laminate flooring, before I re-fit it, I'd like to be sure there are no more leaks under the floor
After the system had been refilled, I ran it for a bit, bled any more air out of it, and ran it for a bit more. I then switched it off and filled the pressure up to a nats over 2 bar and watched it for two days, it didn't move at all. This morning however its moved slighly back towards 2 bar. Its perhaps a drop in the region of 0.05 to 0.1 of a bar. However today is much colder than yesterday, is this likely to be the reason for the small drop?
The boiler is located in the garage where it is subject to much cooler temperatures than the house
I have now dropped the pressure back to 1.5 bar and plan to run it for a few days and keep monitoring the pressure
