fitting a mixer shower
2 Feb 2006
Cheshire
hi can some one advise me as what connections i require to connect a mixer shower, it will run of a combi boiler there are 2 pipes in my airing cupboard 1 22mm and 1 15mm i have the connections from the shower end but not the pipe end they have block ends on them i just need some information if any one could advise me i would be very grateful thanks, chris :idea: :
Did a similar job myself - Presume that if you have a combi then you don't have a tank in your airing cupboard? I would chase the pipework back from the bath/sink taps to a point closest to where you want to fit your mixer. Presume also that as you have a combi then the hot and cold are at mains pressure. Andy
hi
like the previous reply said just decide on where your siting your shower and then plumb into the nearest hot and cold supplies, i take it its a thermostatic mixer shower...???
just want to say thank you to andy and steve for your information, i have had my hot tank taken out and the pipe work is still in the airing cupboard with blank ends on so thank you again it should be quite easy now, i just wasn"t sure, thank you christine
