washing machine won\\\'t fill with water MEC type.
8 Feb 2006
MEC type (HWM6105)..Malaysian made washing machine. Supply voltage 240V..current OK...water supply (hose ok)...but once started ...water won\\\'t fill...spin ok.. :cry:
try and test the solenoid to see if you have power to it
Checked the solenoid resistance, it's too high (4500 ohm)....solenoid specification 220/240V~7 "unclear"...V or W....checked the incoming power supply to solenoid..got 4.5V only.......any suggestion or comment????...which one problem????...incoming power supply generate by relay contactor or the solenoid itself????...confused!!!!!! :confused:
