Garage timber fascias: replace with uPVC?
16 Mar 2005
I have a 1970s style garage. Sectional steel walls with pebble dash outer, corrugated asbestos roof sloping to the rear, with timber fascias and timber cladding at front.
The timber fascia is now rotten. Would it be feasible to replace it using uPVC fascia and cladding materials? I was thinking of using a conventional "L-shaped" uPVC fascia board to fit the garage sides, turned over so it would hang on the roof edge.
A related question. I have previously transported 4m plastic guttering back from the DIY store in a small hatchback car. Just fold the gutter in half! Would this trick work with thicker uPVC fascia boards, I wonder?
Mike
Lol at folding gutter in half! Must have been a warm day as too much bending causes a weakness. :D
Replacement fascia usually starts at 16mm, too hard to bend in half :wink:
Worth paying a small delevery charge, be a shame to snap it all by accident.
ordinary flat board would do for the sides but use the thick stuff if you wish :)
Wickes have 9mm uPVC. I think this is intended for cladding existing timber fascia on houses.
But I think it would be OK to use this as replacement fascia for the garage.
Mike
helllooo mike
the cladding is to protect the wood not replace it
you have to replace rotton wood then cover as the cladding doesnt have enough structural strength
Does it need much structural strength for a garage?
9mm seems solid enough to keep wind and rain off the edges of the roof sheet...or am I underestimating?
Mike
Mike
Actually Yes Mike you are right, the 9 mil would be fine as it would just be 'butting up' to the roof sheet :) Its not as if it would be supporting a row of tiles or anything.
