DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
fusebox problems? any ideas?
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
dj313
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 23, 2006 2:21 pm    Post Subject:
Reply with quote Thanks
Boiler immersion heater element packed in, which caused mcb fuse to trip..
The heating immersion element is being replaced; the MCB fuses are fine; but fusebox for boiler section power output is zero, after checking.
Everything else works on fusebox except boiler power output-there are other fuses connected to this- they are ok, power into the mainwire is zero hence no output from fusebox(boiler section). Is this a safety feature hence no power output to boiler? Do i need to call the sparky?
all ideas greatfully received
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Qedelec
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 23, 2006 2:32 pm    Post Subject:
You need to check the supply FROM the immersion MCB. It is possible that the MCB is now faulty although if its a decent make it will normally take 6000A breaking current.
If this is ok then start checking thje supply cables to the immersion. You will need at the very least a multimeter to measure voltage and continuity.
Please do not tell us you are using a neon screwdriver to check this circuit.
__________________
"Shock me again and I'm gonna turn you off"
Life's a beach.
Back to top
 Alert Moderators
PartPapproved
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 25, 2006 7:33 pm    Post Subject:
Is this the first time the mcb has tripped? , because as said already they have a breaking capacity of 6ka(most do)but they can often only handle a couple of heavy duty breaks before they fail.
Back to top
 Alert Moderators
kai
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 26, 2006 5:44 pm    Post Subject:
Fuse.
Have you checked the 13amp fuse inside the fuse-connection unit to the immersion? (The Switched white box beside the immersion, with a small hatch in it for the fuse, and possibly a neon indicator too, supplying the flex to the immersion).
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Fusebox flick switch won't reset 2 320 Fri Apr 11, 2008 8:23 pm
Meltdown fusebox 14 700 Tue Jun 24, 2008 11:23 am
Fitting an external fusebox 3 280 Wed Jan 23, 2008 2:55 pm
Moving my own MCB (Fusebox) 6 440 Sun Nov 11, 2007 5:28 pm
NAPIT Inspection, testing circuits and awkward fusebox?? 25 2000 Sat Aug 11, 2007 1:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
