Hi, I would be grateful for anyone\\\'s opinion on this. I have bought a seperate cooker and hob, both electric. The hob is 7KW and I will connect that to the existing cooker outlet which i would also like to run a small appliance on through the cooker control unit which has a socket on it. I think I understand through reading the posts on this forum and other sources that I can connect the cooker which is 2.075KW to the downstairs ring main through a spur run from a plug socket via a fused switch unit. But am I correct that if I then turn on appliances such as the washer or the kettle that I will overload the 32Amp downstairs ring main. If so does anyone have any suggestions other than having a new curcuit run? ps sorry for it being a bit long winded.
