DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
leaking stopcock
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
greenbeans
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 3:14 pm    Post Subject:
leaking stopcock
Reply with quote Thanks
Hello. My mains stopcock is leaking from the spindle.Stopcock works ok (ish) but is rough.I need good working order due to imminent arrival of new bathroom suite. plastic incoming pipe, copper after.Stopcock is approx. 25 years old. I cannot at the moment isolate supply in street due to debris (awaiting water authority)Is there anyway I can repair leak or will I have to wait for waterboard to make their valve operational?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JPC
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 3:40 pm    Post Subject:
if u do a search u'll find the answer
__________________
Jamie
Back to top
 Alert Moderators
greenbeans
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 10:52 pm    Post Subject:
stopcock
Thanks JPC. Search results were not specific enough.Search points to possible gland packing problem. With stopcock fully shut there is approx 2 drips of water per second. With stopcock fully open there is approx 1 drip every 2 seconds. The water is leaking along the "shaft" of the stopcock. Does this suggest gland packing? To remove gland nut I have to "turn off at the mains" Posts are unclear if this means turn off at my mains stopcock or turn off at water boards stopvalve in street outside.
Sorry if this seems obvious to all, but I have a vision of a huge plume of high pressure water filling my garage if I don't get it right! Thanks for information.
Back to top
 Alert Moderators
croydoncorgi
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 10:56 pm    Post Subject:
If you turn OFF the stopvalve and then loosen the glandnut ONLY, nothing much can leak out (the water is still off).
But have you tried just tightening the gland nut? 95 times out of 100, that stops glands from leaking.
Back to top
 Alert Moderators
oldskool_plumbski
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 14, 2006 10:52 am    Post Subject:
leaky stop cock.
shut of the stopcock, completely undo the packing gland nut and lift up towards the spindle crotch, place P.T.F.E. tape evenly round the nut about four or five times clock wise, re-do nut up reasonably tight, Job done.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Tue Mar 14, 2006 10:57 am    Post Subject:
You took the words right outa my mouth Oldi icon_wink.gif I do like you moniker icon_lol.gif Wish I`d thought of it.
Back to top
 Alert Moderators
streethawk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 16, 2006 11:27 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Stopcock leaking 5 540 Tue Oct 11, 2005 9:40 am
Leaking stopcock - help! 3 260 Wed Jun 18, 2008 3:05 pm
Leaking internal stopcock 3 760 Sun Oct 30, 2005 1:15 pm
Leaking stopcock spindle 5 620 Sat Mar 25, 2006 1:29 pm
Leaking stopcock 6 700 Sun Oct 02, 2005 7:41 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
