DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Double/Twin FCUs???
This topic originated from the How to page called Fitting a Fused Connection Unit
Click here to return to the page called Fitting a Fused Connection Unit.
  View previous topic :: View next topic
Author Message
jk5
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 4:19 pm    Post Subject:
Double/Twin FCUs???
Reply with quote Thanks
Is it possible to get a double, preferably switched FCU. I need to connect electric oven and ignition for gas hob and have a double socket in place. Is this possible or will I have to remove the double socket and fit two single fcu units, I am trying to avoid this because the lack of clearance means that it must be flush not surface mounted and my walls are made of legendarily hard brick!!
Any other suggestions for a solution would be greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Mar 04, 2006 5:26 pm    Post Subject:
No, you cant get a double FCU, although you can a 3 or 4 gang grid plate, and fit 20amp douple pole switches and fuse modules into it. Search for MK Grid, and MK Edge.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Mar 04, 2006 6:16 pm    Post Subject:
you can also get a metal wall box, a bit bigger than a double, which holds two single FCUs (or an FCU and a socket, or two switches, whatever)
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Mar 04, 2006 6:45 pm    Post Subject:
Thats true - a dual box.
Back to top
 Alert Moderators
jk5
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 10:16 pm    Post Subject:
Cheers guys,
Like the idea of the dual box, if its a little bigger than the one in place for the twin socket then its just a little bit of brick chopping.
Any idea if I can pick one of these up in B&Q or suchlike? Or will I need to try somewhere a bit more specialised? If so know any in the Paisley/Glasgow area?
Found a couple of places online but dont fancy £15 for a box + 2 switched FCU. Seems kinda steep!
Again, thanks for the advice
Back to top
 Alert Moderators
Har_vey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 05, 2006 9:53 am    Post Subject:
You should be able to pick one up at B&Q or any of the DIY places. Called a a split metal box. Should cost about a quid!
Back to top
 Alert Moderators
ebee
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 05, 2006 11:12 am    Post Subject:
correct name is a dual box but sometimes called a bar box
Back to top
 Alert Moderators
Har_vey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 05, 2006 11:33 am    Post Subject:
Back to top
 Alert Moderators
ebee
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 05, 2006 12:15 pm    Post Subject:
Good description that one
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
FCUs from double socket 14 640 Tue Oct 23, 2007 8:52 am
FCUs, Spurs and Rings 3 480 Fri Dec 23, 2005 7:53 pm
FCUs and switches with labels 21 1160 Fri Dec 28, 2007 10:01 am
Multiple FCUs 16 420 Sun Feb 15, 2009 6:29 pm
Double insulated lights from junction box using twin & e 2 1500 Sun May 08, 2005 4:09 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
