I have a Saunier combi boiler which is approx 11 years old and as far as I know hasn't been serviced recently (moved into house 18mnths ago). Recently the boiler has started making a noise when the central heating starts up. When the thermostat starts the boiler up it makes a progressively louder cyclic drumming /slight banging noise which is amplified up the pipe to the radiator above. After a few seconds the noise drops to a constant drumming. Am I right in thinking this is a problem with the pump (possibly bearings??)as the boiler doesnt appear to make the noise when I run the hot water. I have also noticed:
1 The radiator upstairs is much colder on the bottom of the radiator than the top when heating is on, which from looking on Google sounds like the rad has sludge in it.
2. The pressure dial on the front of the boiler which is labelled "1 bar when cold" always seems to be on 1 bar, even when the boiler is hot. Shouldn't the pressure rise as the boiler heats up??
As I am having the boiler serviced would it be worth having the system flushed? I have done other DIY in the past and was considering doing this myself but I was a little reluctant as I believe it is a sealed system and more involved to drain and setup afterwards.
I have arranged for a plumber to visit but I just wanted to know others opinions here.
